06-02-2021 10:37 AM
Hi guys, does anyone have experience with captive portal that redirects user to app download? We need to configure portal so it can detect OS of the device connecting to wifi and redirect it to app on the app store the devices use (App Store or Google Play).
Thanks!
06-02-2021 10:22 PM
Hi Dominik,
I think this would be possible using Ruckus cloudpath
(policy manager) integration with your controller. Though can you tell me the controller model and version you are using to get more information for you from controller configuration perspective.
Best Regards
Vineet
06-18-2021 02:00 PM
Hi, its Virtual SmartZone Essentials 5.2.0.0.699
