AP Latitude and Longitude
I have one question in case you can give me information. I need to get my WiFi Access points latitude & longitude for analysis purposes. The AP's are Cisco. Can I do it via any known WiFi tool like Ekahau or you know any workaround? Normally the AP's are mounted on the high ceilings for a Museum so I can not go to each AP and use my smartphone to locate the latitude and longitude. Moreover, the number of AP's is huge and this option can not be implemented. Let me know In case you got a good solution.
1 REPLY 1
syamantakomer
Community Admin
Community Admin
Hi @Anonymous ,
Thanks for posting your query to RUCKUS community!
Since query is not related to Ruckus, I am not sure if from product side we can help but in general if your APs have GPS module, you should be able to get this information from AP or controller directly (better to ask in CISCO community for correct audience).
About the site survey tools, I found below article which says GPS based survey is supported on ekahau pro. Check the below link if it helps.
https://support.ekahau.com/hc/en-us/articles/228397868-GPS-Assisted-Outdoor-Surveys
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
