[808 Cluster application stopped] on vSZ-E 5.0.0.0.675
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-24-2018 12:13 AM
Two errors occured about 3 hours apart.
808 | Cluster application stopped | Critical | Outstanding | Application [NC] on node [TEST-vSZ] stopped.
Is this a known bug in version 5.0 ? I have downloaded the logs, but I can't open a case, since this is only a test deployment without license.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-24-2018 03:07 AM
This is known and a cosmetic thing, the application actually did not stop.
As soon as you have your license, let us know and we will provide the patch.
Regards
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-24-2018 05:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-24-2018 07:13 AM
Kind regards
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-27-2018 12:36 PM
These messages you are getting because for a system IO intensive scenario on SZ, the check process scripts may not be able to respond in 10 seconds, then led to process checking failed. Solution will be to extend the process check timeout to align with the check alive timeout (10) minutes.
We have a reported issue for this. And the issue will be fixed in 5.0.5.0.0 670+.
No mention of a patch to get us by until this new version.
