02-26-2021 09:36 AM
I was looking at options on unleashed on my R500 and saw Transmit power was set to auto.
But according to the link below it should not be in Auto.
Can someone confirm this is still the case?
https://docs.ruckuswireless.com/unleashed/200.1.9.12/c-SelfHealing.html
02-27-2021 01:01 PM
I’m just wondering that if they say don’t use Auto, why it’s auto by default ?
Also I thought having “screaming” signals was considered bad practice ?
02-28-2021 08:47 AM
Hi Atma,
It seems you are referring the online document for Unleashed 200.1.
Is your AP is on 200.1? If yes, upgrade it.
Auto is the default for all the APs when configured and managed by a controller and this means full power, until ACS feature (Auto Cell Size) is enabled. ACS is only supported on newer version.
02-28-2021 11:22 AM
@syamantak_omer Thanks.
I have the latest firmware and I was wondering about transmit power and that was all I could find about it.
When you say managed by a controller are you referring to a unleashed controller and /or a zone controller ZD or whatever they are called. ?
03-01-2021 05:06 AM
Any controller based APs including Unleashed.
03-01-2021 06:25 AM
About "screaming" signals. Theoretically it is a solid reasoning. But actually -- it is not.
Idea is that unnecessary high signal will create interference to neighbors. Actually it is not really the case. In practice neighbor networks usually have levels -70 -- -80 dbm, often -- even higher, so if your AP power is lowered for 6 db, it is still much over sensitivity level, and you'll get same interference. So in such environment the only question is how many free airtime is there, as all devices on same channel share same airtime. When AP power is higher, data download happens much faster (because higher modulation is used), so it takes less time, which gives more room for all other clients. On power used by clients (by far bigger number than APs) you have no control whatever anyway.
So in real life lowering AP power almost never improves things, except some specific situations. Changing channels may have much higher impact.
This is actually correct for all vendors, but especially for Ruckus, because of Ruckus Beamflex which improves signal in client direction and makes transmitted signal levels much lower for other directions.
