08-06-2024 12:44 AM
Good morning
I'm having the same issue and have not found a solution.
I tried connecting directly to it via LAN cable from Laptop to AP, While PWR is solid green I can connect to the Configure.Me network, but there’s not enough time to set up the AP.
I connected it to the main network, same issue.
08-06-2024 05:25 AM
Hi @LouisBotha
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
08-06-2024 07:12 AM
Hi @LouisBotha
Thank you for the confirmation.
I am redirecting this case to the Unleashed team for the further assistance.
Meanwhile, I would suggest you perform the following once:
- Remove the AP from the network, and connect it directly to your machine. Perform a hard reset on the AP by pressing down the the Reset button for 10-12 seconds and then releasing it. The AP should be powered up by a power adapter or a PoE injector.
- Set your machine's ethernet adapter settings in the subnet of 192.168.0.x
- Try to access the WebUI of the AP using the default IP address: https://192.168.0.1
- Complete the initial configuration including the IP address assignment method and then put the AP back to the network
Please reach out to us for addition queries.
08-13-2024 05:15 AM
Hi
No this did not solve my issues
The unit is still stuck in the boot loop
