7372 Configuration Issues
I am trying to configure the 7372 multimedia hot zone wireless AP through the web interface and under the configuration option I only have device, internet and Ethernet ports.
Where is the option to set up the wireless connectivity?
10 REPLIES 10
Esteemed Contributor II
Did you use the ISP super user login credentials, of 'super' and 'sp-admin'?
If you go to Administration::Management, on the top line, what do you have for Network Profile?
Where did you get this AP?
I have found that i needs a controller, but is there a way to set it up in standalone mode so i dont need the controller?
Standalone means no controller...
Factory default the AP by pressing the indented Hard Reset button for 8+ seconds before release.
The AP will default to 192.168.0.1 IP address.  Connect your PC by Eth cable with 192.168.0.10 on your PC.
You should be able to ping the AP, and open https://192.168.0.1 to access the WebUI.
The Ruckus product uid/pw is 'super' and 'sp-admin'.
If this doesn't work, your AP comes from an ISP who puts a custom configuration on the APs they buy from us.
You can only use those APs with the ISP they came from.
Where did you get your AP?
I have performed a factory reset and used that login and what i mentioned in my first post is what it displayed
The AP was already installed where i work and am trying to resolve the Wi-Fi issue
