what is this problem ?
lasha_chavleshv
Feb  8 08:44:03 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb  8 08:44:03 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb  8 08:44:03 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:459
Feb  8 08:44:03 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
Feb  8 08:44:05 RuckusAP daemon.info hub_registrar: OCSP: 'unknown' on ap-registrar.ruckuswireless.com - withhold query
Feb  8 08:44:08 RuckusAP daemon.err wsgclient[464]: crSocketConn:56 errno:103/Software caused connection abort
Feb  8 08:44:08 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb  8 08:44:08 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb  8 08:44:08 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:460
Feb  8 08:44:08 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
Feb  8 08:44:13 RuckusAP daemon.err wsgclient[464]: crSocketConn:56 errno:103/Software caused connection abort
Feb  8 08:44:13 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb  8 08:44:13 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb  8 08:44:13 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:461
Feb  8 08:44:13 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
10 REPLIES 10
lasha_chavleshv
ap not join on virtual smart zone  3.6
Try reset AP to factory defaults and change the firmware to standalone and join the smartzone again
lasha_chavleshv
i reseted aps , change firmware to standalone , but still a problem on virtual smart zone ,
virtual smart zone block  all port , i do not use firewall  my network .
i did it via cli
vSZ# config
vSZ (config)# lwapp2scg
vSZ (config-lwapp2scg)# policy accept-all
i still a problem , aps not join virtual smart zone , version 3.5.1.0.862
Try below command.
conf
no ap-cert-check
The AP's cert may old cert.
