01-21-2025 03:33 AM
I currently have a vsz hosted on a server and I've installed a new vsz locally. How can I migrate the APs and configurations to this new vsz? Does a backup restore work even if the vsz IPs are different (192.168 to 172.16)?
Gaétan
01-21-2025 09:48 AM
Hi Gaetan,
May I know the firmware version of the old vSZ?
01-21-2025 10:13 AM
Hi Gaetan,
In 5.2.2 version, there is no option to download the Cluster backup however you could take a configuration backup and restore the Configuration backup on new vSZ
NOTE: Configuration backup would have network device's configuration and settings but not the entire Cluster configuration.
To take a Configuration Backup go to Administration->Backup and Restore->Click on Configuration Tab-> Click on Backup.
Once the Backup is taken, click on that Backup taken-> Click on Download
To restore, Login to new vSZ WebUI-> Go to Administration->Backup and Restore-> Configuration-> Restore->Then upload the taken Backup file-> Click on restore
01-21-2025 10:28 AM
Make sure you do the license migration from old vSZ to new vSZ
https://support.ruckuswireless.com/articles/000006122
To move your AP to new vSZ, verify if your APs are discovering controller through DHCP Option 43 or DNS or static, follow the instruction given below
https://support.ruckuswireless.com/articles/000008703
01-21-2025 09:55 AM
Firmware Version
5.2.2.0.1563
01-22-2025 05:22 AM
Merci je vais essayer de faire cela.
Cordialement,
