Why my Ruckus SmartZone 100 won't strart
ayoub_fariat
Since this morning, my Ruckus SmartZone 100 keeps blinking  a red light on power on whit a bips, and can not access  from navigator
7 REPLIES 7
Ankush_Chandan
RUCKUS Team Member
Hi Ayoub,
Can you Ping SZ's IP or could you access it from Console port? If not, try rebooting the SZ and if it still doesn't recover, please open a Support Case.
-Ankush
ayoub_fariat
i did ping on SZ's IP, no connection, i rebooted it man time, i always get the SZ stucked on blinking red led and ringing, how can i access it from console port?
Ankush_Chandan
RUCKUS Team Member
You would need a console cable to physically plug into the SZ100's console port:
Image_ images_messages_5f91c44d135b77e247a128c0_da1d789ee61f17b1f3c53aca370276aa_RackMultipart20190314125060r5p-5343fb76-002c-4cb8-9b59-198a84aaadb8-1096476220.png1552576669
ayoub_fariat
i don't have a console cable and i don't know the other part of connecting it, that means i must plug to the console port of my SZ and the other part of cable??
does it fix the problem??
should i do a factory reset? is there any risk to lose all configs?
thank for  your priceless Help!!
Type a product name
