04-25-2023 07:24 PM
I am using version 6.1.1 of smartzone and have enabled web authentication. After user authentication, the "500 Internal server error" interface often pops up, or the web authentication login interface gets stuck. However, the above two situations do not affect normal wireless usage. Can this be optimized?
04-26-2023 02:05 AM
I would recommend you to open a support case so that we can check the logs to find the root cause.
04-25-2023 07:25 PM
04-26-2023 02:01 AM
Hi @cangqingse
Is this happening with any specific clients like Android or Apple devices?
04-26-2023 02:05 AM
