03-09-2026 11:46 AM
I have a Ruckus Virtual SmartZoneHigh Scale with the below:
Control plane version: 6.1.2.0.1018
Default AP Firmware version: 6.1.2.0.4209
All my access points are showing offline, however, the access points are working.
Any ideas as to what could be causing this?
03-09-2026 12:19 PM
Hi HB,
Please verify below points:
If issue persist, please raise a Support ticket with Ruckus TAC, to investigate further.
Regards
Deepak Kumar
Senior Technical Support Engineer
05-20-2026 11:45 PM
Hi HB,
This behavior could possibly be related to Elastic Search or one of the associated services being offline.
Could you please check the service status from the vSZ CLI using the following command:
show service
If you notice any services offline, I recommend reaching out to RUCKUS Support for further investigation. Otherwise, you may schedule a maintenance window and perform an Elastic Search reindex operation under debug mode. Before proceeding, it is highly recommended to take a configuration backup and, if the deployment is running on VMware ESXi, consider taking a VM snapshot as an additional precaution.
You may also find the following forum reference helpful:
RUCKUS Forums – “How to monitor ES (Elastic Search) health from controller”
https://community.ruckuswireless.com/t5/SmartZone-and-Virtual-SmartZone/Error-For-input-string-quot-...
If the issue still persists after these checks, I would kindly recommend contacting RUCKUS Support/TAC for further assistance.
Also, please ensure that there is active support coverage for both the controller and the access points, as an active support entitlement is generally required to engage RUCKUS TAC. If needed, you may also reach out to your local partner, RUCKUS SE, or RUCKUS sales representative for assistance.
Hope this helps.
