Roaming and captive portal authentication
othmane_douiri_
Hi guys,
I have a network composed of some indoor APs in remote locations. All the APs are connected to a virtual SmartZone in Bridge mode.
I am using an external captive portal server and an external radius for authentication. There is no layer 3 mobility, only one VLAN (one subnet) for all the users.
I have an issue when the user roams from one AP to another: the user is no longer authenticated when he moves to the new AP and thus he is redirected to the captive portal for authentication each time he associate with a new AP.
Does someone have an idea what could possibly cause this or how I can tshoot.
Thank you
2 REPLIES 2
Esteemed Contributor II
Confirm that the roaming is under the Session Timeout or Grace Period configured on the WLAN.
https://support.ruckuswireless.com/answers/000005878
kieran_williams
Hi folks,
Did you find a resolution for this? As we're having the same issue? Does Mesh need to be enabled?
