05-29-2024 12:02 AM
We are planning to replace the existing SmartZone 100 with SmartZone 144.
Is it possible to transfer the licenses we are currently using?
Will it be necessary to repurchase them?
We plan to reuse the existing APs (R510, H510).
What about the required software maintenance and license software maintenance?
If we switch to SmartZone 144, will we need to purchase them anew?
05-29-2024 01:43 AM
Hello @kfts
You can transfer the license between the SZ-100 and SZ-144 after migration.
Please refer the below guide for the SZ-100 to SZ-144 migration process
https://support.ruckuswireless.com/documents/3481-smartzone-sz100-to-sz144-migration-guide
05-30-2024 05:09 PM
Thank you very much!!
09-09-2024 08:10 PM - edited 09-09-2024 08:10 PM
Dear engineer, I replaced the broken sz100 with sz100. But the broken sz100 has license authorization, how should the replaced sz100 handle the license authorization so that it can be used normally? (Currently sz100 is over-insured)
