06-14-2017 08:30 AM
Hello,When configuring hotspot mode (WISpr) in VSZ-H version 3.4.2.x, it is not possible to access the captive portal.
Do not load any portal or service. This was done locally and externally with an AAA server, and in neither way has it worked. Thanks for the help
03-06-2018 04:46 AM
03-06-2018 08:59 AM
hello Dmitry Ivanko, The solution in my case was: 1. Install the vSZ-H controller in its version for three interfaces: Control, administration and cluster. 2. Configure an ip from the public domain (xxx.xxx.xxx.xxx) to which the APs are set. set scg ip xxx.xxx.xxx.xxx. 3. Change firewall policies where ports 8099, 8090 are open.
Regards
03-07-2018 12:21 AM
