Good afternoon,
I'm back from a much-needed vacation and am jumping into making sure my Ruckus assets are healthy and backed up. Usually, I schedule a Maint window in order to perform the cluster backups ( 5.1.1.0.598 VZ-H - 3 nodes in AWS and 5.0.0.0.675 VZ-E single node hosted on-prem), but wondered, if this was indeed necessary? I looked through the documentation for guidance but found only the following excerpt.
"The following message appears: The cluster is in maintenance mode. Please wait a few minutes.
When the cluster backup process is complete, a new entry appears in the Cluster Backups History section with a Created On value that is approximate to the time when you started the cluster backup process."
