09-14-2015 02:23 AM
09-16-2015 07:27 AM
Guy, for an MPLS system to work correctly, you need to ensure that all routers in the network can pass MPLS traffic. You mentioned that you have configured MPLS VPN on PE1, 2, 3 and 4; however did you configure the interfaces connecting these 4 routers to the core router in your topology (P) to pass MPLS traffic on each of the respective interfaces? By this I mean, did you go into the interfaces of this router and configure the "ip mpls" command? The same may need to be done in the Camtel router.
I would start there. You can also do an MPLS ping end to end to ensure that the MPLS tunnel is working as expected.
Case in point, the gateway needs to be able to pass the dhcp request frame to the dhcp server successfully end to end.
This is a bit out of the realms of the controller, but hope it helps.
09-20-2015 03:59 AM
