05-11-2023 07:18 PM
Currently, our virtual machine is running on 30GB of memory, and there are currently 5 online APs with around 200 users. However, the memory usage rate has reached 95%, is this normal? If it is not normal, how much memory should be used appropriately, and what is the approximate memory usage rate?
By the way, we will have 90 online APs and 1500 online devices in the later stage. How much memory should be suitable for this?
05-11-2023 07:51 PM
Hi @cangqingse
I see that you have below hardware resources:
RAM 30 GB
CPU : 8
HDD : 100 GB
AP : 5
Client : 1500
The resources are fine and with this you can manage upto 500 APs and 10000 clients.
I believe the controller version is below 6.0. If it is 6.0 or higher then the HDD should be 150 GB Minimum.
Below is the table for below vSZ-E 6.0 version. Please make sure the resources are as per the below table (Table6):
