05-11-2021 07:24 PM
We have 300 APs managed by a Virtual SMARTZONE controller supported on AWS in version 5.2.2.0.317 (this controller is published on the internet).
We need to migrate the 300 Aps to a new Virtual SMARTZONE controller in version 6 that has been installed the LAN network.
The APs are configured with a static IPV4 address.
How can the migration be done?
05-11-2021 07:28 PM
AP cli script can be used in this case (by zones), please log a case with support and they will check with you on that.
Thank you.
05-12-2021 06:25 AM
Hi Yedinson,
As explained by Dickson, you can use AP CLI script and point the APs to new controller IP. However, there is another way to achieve this.
This is only possible if your both vSZs can talk to each other and also accessible from APs.
05-12-2021 10:47 AM
You can also use the Switchover Clusters features to move AP from one Smartzone cluster to another.
Accessible on the 'MORE' menu when selected an AP, Switch Over Clusters then enter the IP of the new controller you want the AP to belong to.
