Have 2 SZ-100's that are on individual clusters and need to combine into one cluster. How do?
hailey_glenn
Hi all.
Question is basically in the title. I have two SZ-100's that were configured individually (for testing) and are leaders in their own clusters. I can't find any documentation on how to switch one off of its cluster and join the other, so is it at all possible? Or do I have to reset it in order to work?
Let me know if you need anymore info.
Thanks!
3 REPLIES 3
david_saez
Hi Hailey,
you need to factory reset the unit, then do the setup again and join the unit to the existing cluster.
Regards.
David.
Thank you for letting me know
hailey_glenn
I am having a little trouble after resetting the smartzone. After I reset it and it goes into setup mode, the light blinks red, and does it fast, but after a minute or two, it doesn't go solid green. It goes into a slow blinking and still red. Any ideas? Can't seem to find any info online.
Thanks.
