Showing results forย
Search instead forย
Did you mean:ย
Autonomous WLAN like feature in SmartZone
I would like to know if there's autonomous WLAN feature in SmartZone just like in ZoneDirector. How do I enable this feature if it's available?
Thanks and regards,
iftitah
5 REPLIES 5
Smartzone does not have this WLAN configuration because APs already have resiliency by default
Does this mean whenever the AP lost connection to the Smartzone the AP still able to broadcast the SSID?
Yes.
If SSID is not tunnel-mode, the ap on SZ is still able to broadcast the SSID.
thank you. i will test this out.
