Alarms code 960
janko_jeki
Hi all,
We noticed a message:
code 960
[AP Capacity License] limit reached at [90%]
[AP Direct Tunnel License] limit reached at [90%]
Does this mean we need to increase resources?
Virtual SmartZone- High Scale
Controller Version 3.6.2.0.222
AP Capacity and Direct Tunnel License 2072/2151
CPU : 6 CPU(s), 8121 MHz used
Memory : 24576 MB (11304 MB memory active)
Hard Disc : 300.00 GB
With the existing settings, we can go up to 2500 licenses.
Will we compromise our services if we continue to buy licenses without increasing the virtual machine (VMware) resources?
1 REPLY 1
javier_valdes_c
Hi Janko,
The messages [AP Capacity License] limit reached at [90%]
Only tells that your almost run out of AP Capacity licenses.  Let's say por example, you have 100 AP licenses and your controller has 90 APs registered. It means that you only have 10% of licenses available, so that's the reason you're having have that warning.
Type a product name
