I have upgraded my Vsz to 3.6.0.0.510 and upgraded the APs to 3.6.0.0.709. After the upgrade i noticed that almost every AP had a high percentage of connection errors. I let it go for several days and thought i still had a lot of clients connected so it must be working. In the events I see a lot of Force DHCP disconnects. I did not make any changes to that but did double check the settings. Some wlans were not enabled and some set to anywhere from 5-15 seconds. Downgraded the firmware to 3.5.1.0.1026 and the connection errors went away. Has anyone seen this and have any ideas why i am seeing this.
Then it sounds like it's a stats/counting error, especially if no events in the log are present. Again, for those of us who ran the 3.5.1 for a while - and then switched, without any other changes, these errors popped up.
Yes we are, but I believe that's because we enabled the DoS protection and they are having wrong log in attempts. What do you expect when you attempt to login to the network as Bob?
