05-03-2023 08:32 AM
I'm using AT&T and the speed is 1,000 mbps but when I check with RUCKUS the speed reduced to 300 mbps. Can you help how to fix this? This usually happens after the electric outage.
05-06-2023 12:17 PM
I tried the steps you shared but I cannot find ICX7150 Switch or upgrade it. can you help?
05-08-2023 06:15 AM
Hi @hsgo1587
Thanks for your reply,
For detailed understanding, please share the screenshot of the error you are getting while following the steps.
Also please let us know whether you could find the IP address of the ICX7150 Switch or not.
05-04-2023 06:12 AM
Hi @hsgo1587
Greetings of the day,
Thanks for the details provided.
To add the switch to dashboard please check if the switch is running the minimum software code 08090 version, if not an upgrade must be performed.
The ICX7150 Switch will be added automatically if the switch is running the minimum software code 08090, if the switch is showing requesting to connect, please try to gain access via SSH, Telnet, or Console.
1:Find the IP address of the Switch, while you are connected to the Unleashed SSID/Wi-Fi ID.
Run the IP scanner to find the IP address of the Switch.
2:Once you know the IP address if the Switch, gain access via Telnet, SSH, or Console(for console Access the IP Address is not required)
How to Access an ICX Switch remotely via SSH or Telnet, using a Windows computer
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Access-an-ICX-Switch-...
How to console in the ICX-7150-12CP 'Ruckus Switch'
RUCKUS ICX 7150 USB TYPE C CONSOLE (tutorial video for ICX)
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
3:Once you are connected to the Switch, run the next commands. These are the credentials for the switch.
Usernames: Passwords:
admin sp-admin
super Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
Commands:
show version
Note: "show version" will provide detail about the current version running currently.
4: If you are running lower than 08090, you must perform an upgrade, I will recommend the code 08095g UFI which is the recommended code(must be the image starting with SPS)
How to upgrade a switch via Web GUI (ICX7150 Switch)
