assistance in configuring sonos surround audio setup
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-03-2025 08:07 PM - edited 04-03-2025 08:08 PM
Hi
My sonos music system is not working properly there is some issue with the router configuration and surround system is not functioning.
this is what I got from sonos customer care representative
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-04-2025 05:37 AM - edited 04-04-2025 05:41 AM
admin test
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-04-2025 05:43 AM
Hi @raviteja48
Based on the information provided, it appears that you are encountering issues with the RUCKUS-Sonos setup.
We may need to try the steps below to connect the Sonos setup with the RUCKUS Wi-Fi. We need CLI access to the Master Access Point. For this, we need the Master Access Point’s IP Address to access CLI.
Please follow the below steps on how to find the Master AP’s IP Address and access CLI to perform the commands.
Please follow the steps below to access CLI and perform commands:
1. We must identify the ‘current’ IP address assigned by your local router to the RUCKUS Master Access Point. Please log into the RUCKUS Unleashed system and find the Master AP’s IP address.
If you encounter difficulties accessing the above link or if you are unsure of the IP Address of your Access Points, please refer to our guide on finding the IP Address of the Access Point:
You should see the below-Unleashed dashboard after finding the IP Address of the AP. Try to log in. (Refer to the screenshots below)
2. Once we identify the IP address of the Master Access Point, proceed to access remotely the device “Command Line”
Please download the Putty Application and try to log in to the CLI using the Master AP’s IP Address.
Putty download link:https://www.putty.org/
Try the SSH option to log in to CLI (Putty) as described below- Please refer below.
SSH- Port 22
ruckus>
Please enter the below commands once you log in to CLI.
ruckus> enable
ruckus# config
ruckus(config)# show wlan
ruckus(config)# wlan hotspot (Please refer below point***)
ruckus(config-wlan)# no qos directed-multicast
ruckus(config-wlan)# qos directed-threshold 0
ruckus(config-wlan)# end
***The ‘show wlan’ command will display the name of the Wi-Fi Network/SSID, so please put in your Wi-Fi Network/SSID. In the above command, my SSID/Wi-Fi network name is ‘hotspot’ (refer to the below screenshot)
Once you perform all the above commands, please restart your SONOS setup and check.
Let me know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-04-2025 05:57 AM
Hi @raviteja48
Kindly follow the steps outlined in my previous message and let me know the outcome. Should you encounter any difficulties or have further questions, please don't hesitate to reach out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2025 05:50 AM
Hi @raviteja48
Thank you.
