Won't boot after power outage.
JoeT
There is a green light on PWR, and a yellow light on SYST.
I'm not a network guy, need help, my wife and I work from home and are down.
Placed a support ticket with Ruckus and was sent here because I am a lennar home owner. (which is insane I need tech support by phone).
I found someone with same issue and followed the steps suggested which was to do a factory reset. I think I did that but I still can't get this to work.
12 REPLIES 12
Hi @JoeT
As mentioned in my previous post, your Switch is stuck on the boot mode as per the light status you mentioned (amber/orange light on the "SYST" and a green light on the "PWR")
Did you try to reset it as described? If yes, please try to reset it with a paper clip multiple times.
If still reset is not working, please perform the software recovery as described step-by-step in the previous post in the guide.
Please share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
JoeT
I think i figured it out...
JoeT
I don't see the imagine I am supposed to download.
Instructions say to download RUCKUS FastIron 08.0.90k (GA) software release.zip.
But, all i see is:
Hi @JoeT
Thank you for the response and update.
You could find the 08.0.90k patch on the same page. Please refer to the below screenshot.
JoeT
Capture.PNGI'm stuck at host is not alive.
