09-21-2024 06:12 PM
Like the subject says, I upgraded to 09.0.10j. The web console doesn't load even though it shows it in the configuration
RuckusSwitch(config)#show web
HTTP server status: Enabled
HTTPS server status: Enabled
No web connection.
I have also tried 09.0.10j_cd3 with the same issue (see the results below)RuckusSwitch(config)#show flash
Stack unit 1:
Compressed Pri Code size = 29360128, Version:09.0.10jT211 (SPS09010j_cd3.bin)
Compressed Sec Code size = 29360128, Version:09.0.10jT211 (SPS09010j_cd3.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 983105536
I also noticed during boot up an error.
Error [1 ui_common_send: Not able to apply - itc error please try again] parsing line: [web-management http]
I follow the instructions here -> https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-3A82588D-F1EF-4325-8396-EED525B9D24...
I have tried to change the IP as suggested -> https://community.ruckuswireless.com/t5/ICX-Switches/ICX-7150-9-00-10-Web-Service/td-p/39285
no luck.
10-07-2024 01:24 PM
Hi @EarthLifeForm
Thank you for your prompt response and update.
I kindly request you to once again try the steps as outlined in my previous message and verify the results.
I appreciate your patience and understanding.
10-07-2024 01:26 PM
RuckusSwitch#configure terminal
RuckusSwitch(config)#web-management http
HTTP already enabled
RuckusSwitch(config)#aaa authentication web-server default local
RuckusSwitch(config)#write memory
write memory is in progress, please wait...
write memory completed. No new config is added.
No web connection.
Same results when navigating to
Both HTTPS and HTTP are not working
10-07-2024 01:55 PM
Hi @EarthLifeForm
10-08-2024 05:14 AM
Hi @EarthLifeForm
Please use the private chat option to respond so we can proceed further.
10-18-2024 02:03 PM
Hi @EarthLifeForm
Thank you for your patience.
As discussed on the private chat, I will check on the lab regarding the web portal access.
Meanwhile please refer to the link about the VLAN.
