Switch and AP down after power glitch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-28-2023 10:27 PM
We had a power glitch and the switch and access point are completely down. This happened in the past and I used to be able to reset but not this time. AP has no power from the switch. I tried to reset the switch but all lights are stuck blinking amber continuously. Tried to console in with no luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-28-2023 10:56 PM
The switch and AP has been down all day. Tried to reset and console in all day long with no luck. All the status lights are continuously blinking amber color lights. It seems like the switch is stuck trying to boot and won’t boot all the way to get anywhere.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-29-2023 05:54 AM
Hi @nataliebear04
Greetings of the day,
To solve this issue please try to reset your switch again ( this process sometimes needs to be done multiple times ) as mentioned below.
- Remove power from the switch.
- Press and hold the Reset button while applying power to the switch.
- After all the system LEDs flash amber, release the Reset button.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-29-2023 07:53 AM
Hi Jayavidhya,
I tried resetting again this morning by removing the power, holding the reset and plugging the cable back in, release when all system lights are blink Amber and nothing is happening. All system lights just continue to blink Amber. It’s been stuck doing that all night after I tried to reset it multiple times yesterday as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-29-2023 08:26 AM
Hi @nataliebear04
Thanks for your response.
Please share the image of the switch showing the LED status using the below method.
you can also drag it to the chat
