12-30-2022 11:44 AM
I am having trouble connecting my SONOS ONE system to our home. After calling SONOS they directed me to call Ruckus to get the wifi merged to all the modems as one that way the SONOS won’t be confused on where to connect. I need assistance merging the Wi-Fi’s
12-30-2022 12:03 PM
Hope you are doing well !
The Access Points have already Multicast and Broadcast enabled, therefore the other Sonos device can see each other, now there is another configuration for multicast that you can run, however must be configured via CLI (command line interface), using any external application such a Putty or Mobaxterm, lo let me add the command and the steps.
1: Find the IP address of the Master Access Point, this can be found in , Unleashed Dashboard or unleashed APP , or you can use the next guide to discover your network device's IP address.
2: Now you know the IP address, you need to gain remote access to the Master Access Point using any of the next two Application: Putty or Mobaxterm, you can follow up the next guide:
3: You will be requested for credentials which must be the same you used in the Unleashed APP or Dashboard, if you don't know the credential test the next combination:
Username: Passwords:
admin sp-admin
Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
4: Once you get access you need to run the next set of commands to disabled Directed Multicast/Broadcast.
Command |
Explanation |
no qos directed-multicast |
This prevents the WLAN from converting multicast traffic to unicast |
qos directed-threshold 0 |
This disables BOTH directed broadcast and directed multicast on the SSID. If there is only a single client, it will receive broadcast traffic as broadcast and multicast traffic as multicast. |
SSH to the Master Access Point l ‘IP address’
Go to enable then AP-Mode
Ap-mode
ruckus> enable
ruckus# ap-mode
You have all rights in this mode.
ruckus(ap-mode)#
ruckus(ap-mode)# set qos eth0 directed multicast disable
Directed Multicast ingress packet processing is Disabled on interface eth0
OK
ruckus(ap-mode)# set qos eth1 directed multicast disable
Directed Multicast ingress packet processing is Disabled on interface eth1
OK
ruckus(ap-mode)# set qos eth0 igmp disa
IGMP Snooping is Disabled on interface eth0
OK
ruckus(ap-mode)# set qos eth1 igmp disa
IGMP Snooping is Disabled on interface eth1
OK
ruckus(ap-mode)# set qos eth1 classification disa
QOS processing is Disabled on interface eth0
OK
ruckus(ap-mode)# set qos eth0 classification disa
QOS processing is Disabled on interface eth1
OK
ruckus(ap-mode)#
ruckus(ap-mode)# quit
Your changes have been saved.
Best Regards
Fernando Vasquez
