โ08-11-2023 08:38 AM
My rukus routers are not powering up the one in 1st floor and 2nd floor. How to turn them on? As I don't see any power switch
โ08-11-2023 10:45 AM
Hi @Raghukm
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
โ08-11-2023 11:38 AM
Hello imran, the rukus wireless was up and running till 7 30 AM this morning. A power outage after that messed up all the devices. I had these devices for 2 years now
I have an orange and green light on the box near My att router. I am unable to attach picture to this post. Is there any email address that I can share picture?
โ08-11-2023 11:42 AM
Hi @Raghukm
As mentioned in my previous post, please login on the forum to attach the pictures.
Thank you again.
โ08-11-2023 11:47 AM
Yes, I saw that later and added the photos to my account
