Ruckus system randomly cycling
ajc
My home has  ICX7150-C12-Switch and 2 r510 ap.  The Ruckus system seems to reset randomly.  The ATT fiber router/modem is not as internet is available through ATT.  The switch does not show up in the Unleashed app but the access points do.  I connected my laptop directly to the switch but cannot get pass the login (192.168.1.100) using any of the passwords I originally got from the tech ( super &sp-admin, admin & ruckus). Called Ruckus and they say i must post to forum.  Any assistance would be appreciated.  Home built in 2019.
33 REPLIES 33
ajc
The log exceed 20000 characters so i am attaching first part.  Note I have one of the access points unplugged, but plugged it back in about 15 minutes before generating the log.
telnet@ICX7150-C12 Switch>show log
Syslog logging: enabled ( 0 messages dropped, 0 flushes, 1 overruns)
    Buffer logging: level ACDMEINW, 4000 messages logged
    level code: A=alert C=critical D=debugging M=emergency E=error
                I=informational N=notification W=warning
Static Log Buffer:
Jun  9 06:14:51:I:System: Stack unit 1 POE  PS 1, Internal Power supply  with 124000 mwatts capacity is up
Dynamic Log Buffer (4000 lines):
Jun 12 15:10:54:I:Security: telnet login by un-authenticated telnet user from src IP 192.168.1.119 from src MAC ac74.b1bc.a264 to USER EXEC mode
Jun 12 15:05:31:I:STP: VLAN 1 Port 1/1/3 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 15:05:29:I:STP: VLAN 1 Port 1/1/3 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 15:05:27:I:STP: VLAN 1 Port 1/1/3 STP State -> LISTENING (MakeFwding)
Jun 12 15:05:27:I:System: Interface ethernet 1/1/3, state up
Jun 12 15:05:08:I:System: Interface ethernet 1/1/3, state down
Jun 12 15:05:08:I:STP: VLAN 1 Port 1/1/3 STP State -> DISABLED (PortDown)
Jun 12 15:05:08:I:STP: VLAN 1 Port 1/1/3 STP State -> FORWARDING (PortDown)
Jun 12 15:04:51:I:STP: VLAN 1 Port 1/1/3 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 15:04:49:I:STP: VLAN 1 Port 1/1/3 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 15:04:46:I:STP: VLAN 1 Port 1/1/3 STP State -> LISTENING (MakeFwding)
Jun 12 15:04:46:I:System: Interface ethernet 1/1/3, state up
Jun 12 15:04:24:I:System: PoE: Power enabled on port 1/1/3.
Jun 12 01:04:55:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:04:53:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:04:50:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:04:50:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:04:47:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:04:47:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:04:47:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (PortDown)
Jun 12 01:04:47:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:04:47:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:04:44:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:04:44:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:04:44:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:04:18:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:04:16:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:04:13:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:04:13:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:04:10:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:04:10:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:04:10:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:03:20:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:03:18:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:03:15:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:03:15:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:03:12:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:03:12:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:03:12:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:02:48:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:02:46:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:02:43:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:02:43:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:02:40:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:02:40:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:02:40:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:01:51:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:01:49:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:01:46:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:01:46:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:01:43:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:01:43:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:01:43:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:01:18:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:01:16:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:01:13:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:01:13:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:01:10:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:01:10:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:01:10:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 01:00:19:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 01:00:17:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 01:00:14:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 01:00:14:I:System: Interface ethernet 1/1/12, state up
Jun 12 01:00:11:I:System: Interface ethernet 1/1/12, state down
Jun 12 01:00:11:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 01:00:11:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:59:48:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:59:46:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:59:43:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:59:43:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:59:40:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:59:40:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:59:40:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:58:49:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:58:47:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:58:44:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:58:44:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:58:41:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:58:41:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:58:41:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:58:17:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:58:15:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:58:13:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:58:13:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:58:10:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:58:10:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:58:10:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:57:18:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:57:16:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:57:13:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:57:13:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:57:11:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:57:11:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:57:11:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:56:47:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:56:45:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:56:42:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:56:42:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:56:40:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:56:40:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:56:40:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:55:50:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:55:48:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:55:45:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:55:45:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:55:43:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:55:43:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:55:43:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:55:17:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:55:15:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:55:12:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:55:12:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:55:09:I:System: Interface ethernet 1/1/12, state down
Jun 12 00:55:09:I:STP: VLAN 1 Port 1/1/12 STP State -> DISABLED (PortDown)
Jun 12 00:55:09:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (PortDown)
Jun 12 00:54:18:I:STP: VLAN 1 Port 1/1/12 STP State -> FORWARDING (FwdDlyExpiry)
Jun 12 00:54:16:I:STP: VLAN 1 Port 1/1/12 STP State -> LEARNING (FwdDlyExpiry)
Jun 12 00:54:13:I:STP: VLAN 1 Port 1/1/12 STP State -> LISTENING (MakeFwding)
Jun 12 00:54:13:I:System: Interface ethernet 1/1/12, state up
Jun 12 00:54:10:I:System: Interface ethernet 1/1/12, state down
Hi @ajc
Based on the description it seems like SSH and LLDP were not enabled, so please try to upgrade it using the below commands.
Switch(config)#configure terminal
Switch(config)#crypto key generate
Switch(config)#aaa authentication login default local
Switch(config)#lldp run
Switch(config)#write memory
Note: give 10 minutes after changes, if it does not join, hit add from the Unleashed dashboard.
ajc
Unable to login with all the suggested passwords.  I tried to reset passwords using the suggested links but cannot get the terminal to accept input in boot.  Tried both Mobaxterm and Putty.  attaching screen shot below.
Ruckus Networks Bootloader: 10.1.26T225 (Nov 29 2022 - 04:43:18 -0800)
Booted from partition 2
DRAM:  Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Crashkernel Disabled
device 0 offset 0xbfe00, size 0x200
Enter 'b' to stop at boot monitor:  0
device 0 offset 0x0, size 0xc0000
Uboot Checksum Verification: PASS
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
 33554432 bytes read: OK
Image Checksum Verification: PASS
## Loading kernel from FIT Image at 70000200 ...
   Using 'conf@1' configuration
   Trying 'kernel@2' kernel subimage
     Description:  Ruckus Linux MN VER=08.0.95k
     Type:         Kernel Image
     Compression:  lzma compressed
     Data Start:   0x7024fac8
     Data Size:    2400635 Bytes = 2.3 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x61008000
     Entry Point:  0x61008000
     Hash algo:    crc32
     Hash value:   e0295445
     Type:         Kernel Image
     Architecture: ARM
     OS:           Linux
     Hash algo:    crc32
   Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  Ramdisk -rootfs
     Type:         RAMDisk Image
     Data Start:   0x704a0638
     Data Size:    24878012 Bytes = 23.7 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00000000
     Entry Point:  0x00000000
     Hash algo:    crc32
     Hash value:   907251b3
## Loading fdt from FIT Image at 70000200 ...
   Trying 'fdt@3' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x7049e3a0
     Data Size:    8671 Bytes = 8.5 KiB
     Architecture: ARM
     Hash algo:    crc32
     Hash value:   85a08cb4
   Loading fdt from 0x7049e3a0 to 0x65008000
   Booting using the fdt blob at 0x65008000
   Uncompressing Kernel Image ... OK
   Using Device Tree in place at 65008000, end 6500d1de
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
Mounting file system.PLATFORM MN
dd cmd: UBI
dd cmd: UBI
dd cmd: UBI
ajc
Hi
Tried the various password combinations and none work when I log in from the ruckus web page at 192.168.1.100.  I tried to login via wifi and via ethernet.  I am able to login from the app but cannot see the switch in the app.  The app login credentials does not work on the webpage.
One r510 has all LED green except AIR is unlit.
Second r510 has all LED Lit except CTL and AIR are unlit.
Hi @ajc
If the credentials doesn't work we need to perform the password recovery process.
We need physical access to the ICX-7150-Using the console connection
Here is a short guide :
Short Guide for password recovery :
https://support.purdi.com/hc/en-gb/articles/360016495292-Ruckus-ICX-Password-Recovery-Resetting-a-Sw...
Video link as reference : https://www.youtube.com/watch?v=XJS28DWbHM4
1.Start a CLI session over the serial ( console access) interface to the RUCKUS ICX device.
2-Enter OS mode. This uses a key combination and drops below the fastiron operating system
Key Combination: Ctrl+y, release, tap 'm', tap 'Enter'
OS>
4-just write reset
OS>reset
5-.While the system is booting, before the initial system prompt appears,
enter b to enter the boot monitor mode.
In this Part you have to press B before the counter ends
6-Enter no password. (You cannot abbreviate this command.)
ICX7650-Boot> no password
00 00 00 00
OK! Skip password check when the system is up.
7-Enter boot. This command causes the device to bypass the system password
check.
ICX7650-Boot> boot
8-After the console prompt reappears, assign a new password.
device> enabledevice# configure terminal
device(config)# username USERNAME password PASSWORD
