07-19-2023 02:49 PM
We had a power outage a few days ago and now my switch is showing as disconnected. I saw other posts about the partition, but I'm not sure how to proceed since I can't ssh into the switch (IP address isn't responding). I've tried power cycling a few times with no help. Ruckus customer service has been no help and I'm not super technical.
There are about 20 or 30 neighbors that all have the same problem as per our community facebook group. Ruckus please help!
07-19-2023 02:55 PM
Hi @Cbaddy
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working after a power outage.
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
07-19-2023 09:12 PM - edited 07-19-2023 09:18 PM
ok...so I got access to the switch CLI and it seems it has booted off the wrong partition.
So I started the sequence of commands that you have posted before, but I get the following error
I've also attached the show flash command as well.
Any ideas what I'm doing wrong?
07-20-2023 08:41 AM
Hi @Cbaddy
Please enter below commands and try.
reload (This command will reboot the Switch)
y (Wait until the Switch comes up after reboot and restart Putty, perform next commands)
copy flash flash secondary
07-20-2023 09:36 PM
"copy flash flash secondary" and "boot system flash secondary yes" didn't resolve the problem.
I ended up solving the problem using 3rd party instructions on how to update the firmware using a USB stick.
While I will mark this as resolved, to be honest, it's not because of the support from the Ruckus staff. I am very disappointed in the documentation and support from the Ruckus team. The documentation is not written so an average consumer can understand and execute it. I understand you sell enterprise equipment, but Ruckus decided to partner with Lennar, and now you decided to drop support. After this experience, I have no desire to ever buy another piece of Ruckus equipment. I'm now looking for alternatives to actually replace the entire setup.
I think you have an opportunity to be better and that would start by really going through your documentation and improving it. There is no Mac OS support and none of it is written for the average consumer. Average consumers are not telneting or SSH'ing into a network switch or AP. You should at least have a GUI interface where I can load a FW file from a website. This is something that has been on every consumer AP I've had for decades.
