10-25-2023 01:05 PM - edited 10-25-2023 01:11 PM
After a recent power surge, ruckus R320 extender is no longer working and has no lights on.
10-25-2023 01:53 PM
Hi @Cbull
As per the case description, I understand that your RUCKUS setup is not working after a power outage.
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
10-25-2023 01:53 PM
Hi @Cbull
10-31-2023 02:50 PM
sorry about the delay as you can see the power light is green and the system light is amber.
10-31-2023 03:27 PM
Hi @Cbull
As you mentioned and we can see from the picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. And this is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
First, we will try to reset the Switch as described below:
Below is the Video link for your reference:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable both together as described in steps 2 & 3 in the guide link.
