09-26-2023 02:47 PM
My setup: Ruckus Switch ICX 7150 C12P is connected over lan to 2 Ruckus access points (Model: R510).
Recently, after an electric surge the access points doesn't seem to have any power. The switch is connected to AP over PoE ports. I did reset the switch and the APs both but still the problem persists. However, if I connect an external power source to the AP, then they light up.
I suppose, either the PoE is not functioning and/or the switch is not working.
What could be the possible resolution ?
09-26-2023 02:55 PM
Hi @shantnu
Hope you are doing well!!!
As per the case description, I understand that your RUCKUS setup is not working after a power outage/surge, and Access Points do not have power.
Could you please let us know the answers to the below query to assist you better?
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let me know the answers the above query or let me know if you have any queries in this regard.
09-26-2023 07:48 PM
The first 2 cables are connected to the APs and the third is from the modem. Below is the picture of a AP with no power, it is connected to the switch on PoE port.
09-27-2023 08:16 AM
Hi @shantnu
As per the picture you shared, Switch seems to be in a normal state. However, we may have to check the Switch PoE ports configurations/information to know and troubleshoot to get the PoE ports working.
Please follow the below steps to access CLI and help me with the output of the below-mentioned commands.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show interface brief
10-02-2023 07:23 PM
Tried connecting to the ruckus switch but it doesn't work. The switch doesn't have a IPv4 address assigned and when I try with IPv6 address the command fails with "no route to host". I tried directly connecting to the system to switch and thru the router as well.
