10-23-2023 01:08 PM
I am a Lennar SmartHome homeowner and our Ruckus ICX-7150 switch stopped working. It doesn't turn on and has no status lights on. I have tested and confirmed that the power outlet it is plugged in is working. I have also tried replacing with a different power cable that is known to be working but no luck. The router is also confirmed working as I have Wi-Fi working as expected. But all the devices (Ruckus Access Points, Ring Doorbell, Cameras, Door lock, etc.) that are connected to the Ruckus switch are all offline.
Any help is appreciated.
Thanks,
Glenn
10-24-2023 08:18 AM
Hi @glenn_v
Greetings of the day!!!
Thank you for sharing the requested PICTURES AND VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged into a power outlet there is no power to the Switch. Also, you tried to reset the Switch. And you confirm that the Switch is plugged into a well-known outlet/power source also tried with different cords. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again for your patience and co-operation.
10-23-2023 04:49 PM
Hi @glenn_v
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
10-23-2023 11:14 PM
Here are the photos I've taken:
Using the original cable:Original Cable Pic 1
Original Cable Pic 2
Original Cable Pic 3
Original Cable Pic 4
Using a new working cable:New Cable Pic 1
New Cable Pic 2
New Cable Pic 3
I have also uploaded the videos to the provided Google Drive URL.
Thanks,
Glenn
10-24-2023 08:18 AM
Hi @glenn_v
10-24-2023 08:52 AM
Thank you very much Imran for your assistance. You're the best! 🙂
I have requested an RMA via chat as you suggested.
10-24-2023 08:54 AM
Hi @glenn_v
Great!!! Good to know that your RMA request has been initiated.
Have a great day ahead!!!
