Ruckus ICX 7150 and inline power- not working
bbatjargal11
Ruckus ICX 7150-C12P switch stopped working. SYST light amber, PWR light green. Consoled in to switch and tried to reset. Getting: "ERROR: can't get kernel image!"
ICX7150-Boot>reset
resetting ...
Next boot is from primary
verify_uboot_uimage: Cmd sf probe 0:0
Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size device 0 offset 0x0, size 0xc0000
SF: 786432 bytes @ 0x0 Read: OK
using GPIO[7] to reset
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
Logging is Enabled...
UBOOT: BE Mode
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
SF: Detected MX25L6405D with page size Unlocking L2 Cache ...Done
Net: Registering BCM xgs eth
Broadcom XGS Iproc Ethernet driver 0.1
Using GMAC0
gmac_mac_init: Chip ID: 0xb160
r = 0x0, addr = 0x1, devad = 0xffffffff, phy_id = 0x600d84aa
Add phy reset delay
Add phy reset delay
Basic ethernet functionality initialized
bcm_xgs_gmac-0 [PRIME] ETH MAC: 34:20:e3:31:bb:25
SF: Detected MX25L6405D with page size Flash set to SECONDARY FL
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size done
Valid environment: 2
SF: Detected MX25L6405D with page size device 0 offset 0xbfe00, size 0x200
SF: 512 bytes @ 0xbfe00 Read: OK
SF: Detected MX25L6405D with page size Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Flash set to SECONDARY FL
Valid environment: 1
Booted From: Uboot partition 1
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
7 ecc_errors after reading 1b48000:1b49800
iproc_nand_read_page returned 2
NAND read from offset 0 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
1 ecc_errors after reading 5b48000:5b49000
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
ICX7150-Boot>ERROR: can't get kernel image!
12 REPLIES 12
Followed steps - switch not booting. All amber lights still flashing. This is extremely disruptive to our lives - would appreciate some real troubleshooting assistance over the phone or chat. I've already tried couple of the other instructions on this forum - but it is not helping.
Here's the putty results:
UBOOT: BE Mode
Using GMAC0
Add phy reset delay
Add phy reset delay
bootdelay: ===
Booting image from Secondary
4 ecc_errors after reading 5b48000:5b49c00
0 bytes read: ERROR
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
8 ecc_errors after reading 1b48000:1b49c00
0 bytes read: ERROR
ICX7150-Boot>
Hi @bbatjargal11
I see you have used the ‘enable’ command for the ‘boot>’ which is an incorrect step to proceed with the software recovery.
Please initiate, with ‘setenv’ commands steps as described in the software recovery guide. (please refer to the below screenshot)
Please help us with the screenshots if there are any errors and let us know if you are stuck at any point in the software recovery process.
ping 192.168.0.2 was showing not alive results. Ran the system recovery steps nevertheless and looks like it is booting now.
ICX7150-Boot>ping 192.168.0.2
Change GMAC speed to 1000MB
Using bcm_xgs_gmac-0 device
ping failed; host 192.168.0.2 is not alive
ICX7150-Boot>printenv
baudrate=9600
ipaddr=192.168.0.3
serverip=192.168.0.2
netmask=255.255.255.0
gatewayip=192.168.0.2
uboot=mnz10115.bin
image_name=SPR08061a.bin
ver=10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Environment size: 189/16379 bytes
ICX7150-Boot>saveenv
Saving Environment to SPI Flash...
baudrate=9600
ipaddr=192.168.0.3
uboot=mnz10115.bin
ICX7150-Boot>setenv image_name SPS08090k.bin
ICX7150-Boot>update_primary
Updating PRIMARY image over TFTP
Load addr=0x70000000
TFTP from server 192.168.0.2; our IP address is 192.168.0.3
Filename 'SPS08090k.bin'.
Load address: 0x70000000
Loading: #################################################################
1021.5 KiB/s
done
Bytes transferred = 29360128 (1c00000 hex)
img_sz=0x1c00000 block_count = 0x1c
NAND erase.spread: device 0 offset 0x0, size 0x1c00000
Erasing at 0x1a00000 -- 100% complete.
OK
NAND write: device 0 offset 0x0, size 0x1c00000
29360128 bytes written: OK
TFTP to Flash Done.
ICX7150-Boot>update_secondary
Updating SECONDARY image over TFTP
1019.5 KiB/s
done
NAND erase.spread: device 0 offset 0x4000000, size 0x1c00000
Erasing at 0x5a00000 -- 100% complete.
OK
NAND write: device 0 offset 0x4000000, size 0x1c00000
TFTP to Flash Done.
ICX7150-Boot>setenv uboot mnz10115.bin
ICX7150-Boot>update_uboot
Loading image to Uboot Partition 2
Filename 'mnz10115.bin'.
Load address: 0x61007dc0
1018.6 KiB/s
done
Bytes transferred = 786944 (c0200 hex)
SF: Detected MX25L6405D with page size sf erase 0x0 0xc0000
SF: 786432 bytes @ 0x0 Erased: OK
copying uboot image to flash, it will take sometime...
sf write 0x61007fc0 0x0 0xc0000
SF: 786432 bytes @ 0x0 Written: OK
TFTP to Flash Done.
ICX7150-Boot>reset
resetting ...
Next Boot is from Secondary
verify_uboot_uimage: Cmd sf probe 0:1
Booted from partition 2
UBOOT: BE Mode
Using GMAC0
Add phy reset delay
Add phy reset delay
Access set to SECONDARY FL..
SF: Detected MX25L6405D with page size Flash set to PRIMARY FL
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Access set to SECONDARY FL..
SF: Detected MX25L6405D with page size Access set to SECONDARY FL..
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Flash set to PRIMARY FL
Booted From: Uboot partition 2
bootdelay: ===
33554432 bytes read: OK
Using 'conf@1' configuration
Trying 'kernel@2' kernel subimage
Description: Ruckus Linux MN VER=08.0.90k
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x7024fcd0
Data Size: 2401842 Bytes = 2.3 MiB
Architecture: ARM
OS: Linux
Load Address: 0x61008000
Entry Point: 0x61008000
Hash algo: crc32
Hash value: c027c7ec
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at 70000200 ...
Trying 'ramdisk@1' ramdisk subimage
Description: Ramdisk -rootfs
Type: RAMDisk Image
Data Start: 0x704a0cb8
Data Size: 23843872 Bytes = 22.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: crc32
Hash value: 1e3b36e9
## Loading fdt from FIT Image at 70000200 ...
Trying 'fdt@3' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x7049ea60
Data Size: 8607 Bytes = 8.4 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 6fc9a37b
Loading fdt from 0x7049ea60 to 0x65008000
Booting using the fdt blob at 0x65008000
Uncompressing Kernel Image ... OK
Using Device Tree in place at 65008000, end 6500d19e
Starting kernel ...
Mounting file system...
booting with 4.4 kernel
PLATFORM MN
dd cmd: UBI
Config partition mounted
Resource partition is mounted!!
Processing packages from secondary partition
Incompatible version of booted application and packages stored in UFI image
Error, cannot install packages
Uninstalling old packages if any..
Error in processing packages
Package installation is incomplete, related functionalities may not be available
dhcpd executable file is not present.
Starting up system statistics daemon...
Starting systatsd done
Starting up health monitor daemon...
Log Level 7: Daemonized systatsd
Systatsd Logging Env is not set, initializing loglevel to: 7
Setting connection to systemlogger
Starting hmond done
Hmond Logging Env is not set, initializing loglelvel to: I
Backup is fine
Kernel crashdump is disabled.
dma_mem_base: 0x96000000, dma_mem_len: 0x8000000, warm_mem_base: 0x9f500000, warm_mem_len: 0xb00000
Creating TUN device
Starting TPM Infra
Group tss and User tss created
kernel.hostname = localhost
hostname set to localhost
Starting TCSD Daemon
TCSD Up and Running
Enabling time stamp.
Starting the FastIron.
USER=root
boot_partition=sec_partition
HOME=/
GCOV_PREFIX=/fast_iron
ethaddr=34:20:e3:31:bb:25?
TERM=vt102
PATH=/sbin:/usr/sbin:/bin:/usr/bin
crashkernel=64M@0x70000000
ip=192.168.0.3:192.168.0.2:192.168.0.2:255.255.255.0:MN:eth0:off
SHELL=/bin/sh
PWD=/
i2c-0 i2c Broadcom iProc I2C adapter I2C adapter 2
i2c-1 i2c Broadcom iProc I2C adapter I2C adapter 2
FIPS Disabled:PORT NOT DISABLED
platform type 90
OS>
Loaded Image SPS08090k from Sec Built on (UTC): Tue Feb 23 08:09:48 2021
Enabling Console Logging
Hotplugger Daemon Initialized ..
External USB disk is not mounted or plugged in.
set_board_level: gi_board_type = 116[ 70.847438] linux-kernel-bde: map phys range 0x3200000-0x3240000 to 0xb0ca0000-0xb0ce0000
[ 71.092278] linux-kernel-bde: map phys range 0x88100000-0x90100000 to 0xa8ca0000-0xb0ca0000
DMA pool size: 134217728
PHY Reset De-asserted
sw_pp_sdk_init:136 ToR init
SOC unit 0 attached to PCI device BCM56160_B0
Firmware version from File: 2.1.1
Pre Parsing Config Data ...
Warning: This operation would close all existing SSH connection.
Error! 1/3/1 speed is 1G. A stack-port needs at least 10G speed.
Error! 1/3/2 speed is 1G. A stack-port needs at least 10G speed.
Going to sleep forever...
System initialization completed...console going online.
UNIT 1: compiled on Feb 23 2021 at 00:00:27 labeled as SPS08090k
(29360128 bytes) from Secondary SPS08090k.bin (Non-UFI)
SW: Version 08.0.90kT211
Compressed Secondary Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compiled on Thu Jan 31 07:08:55 2019
HW: Stackable ICX7150-C12-POE
Serial #:FEK3806S0KX
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 7 second(s)
The system started at 02:03:45 GMT+00 Sat Jan 01 2000
========== WARNING: Boot-monitor version mismatch!!! ==========
========== Please use "show boot-monitor" command for details ==========
=============== WARNING: FI image is not booted from UFI!!! ===============
====== Please download UFI image and reboot the system for full functionality ======
Press Enter key to login
Successfully notified stack role 'none' to hmond
enable output as below.
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#
Hi @bbatjargal11
Could you please share the output of the below commands?
show version
show flash
show inline power
show interface brief
Type a product name
