06-25-2026 06:18 AM
I have been using the ICX7150-C12P switch from October 2018 and I noticed today morning device has no power and no lights. All my smart devices are down. I tried restarting the switch by disconnecting the power cable and ethernet connections but no luck. please help on this.
06-25-2026 07:45 AM
Hi @Mahe015
Based on the troubleshooting performed, your ICX-7150-C12P Switch is not responding properly, and it is dead when plugged to a working power outlet. A hard reset was also attempted; however, the issue still persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, Please use the private chat option to respond so we can proceed further. For your reference, I have included a screenshot below.
06-25-2026 11:44 AM
Hi @Mahe015
I’ve raised an RMA case and sent you a private message with the RMA details.
You will receive further notifications from the RMA case about shipping and delivery.
Please check and let me know if you have any questions.
If your issue has been fully addressed, please click the Kudos button and mark the responses as an Accepted Solutions.
