10-26-2023 08:02 PM
Ruckus ICX 7150-C12P router not working after the sudden power outage.
i followed all the instructions given on Ruckus website,
1. Tried to disconnect from the Power outlet the ICX-7150 and reconnected.
2. tried to press the reset button using a paper clip/stick
but even after doing all these, the device and extender are still not connected to network
10-27-2023 08:07 AM
Hi @waanrekr007
Kind regards,
Sofia Gätjens
10-29-2023 05:31 AM
Thanks everyone.
i did the reset 2-3 times, and now seeing the network is up. Able to access internet now.
thanks everyone for kind replies.
10-26-2023 10:42 PM
Same thing happened to me. Was working fine for 2 years. To Troubleshoot I've done factory resets on the Switch and the two APs to start the configuration over. I have Wifi and can connect but can not get on the internet. multiple Speed tests all fail starts with downloading but fails.
10-27-2023 08:07 AM
Hi @waanrekr007
Kind regards,
Sofia Gätjens
10-27-2023 08:08 AM
Hi @Yappy_UCF
Hope you are doing well.
As this case is raised by @waanrekr007
To avoid confusion with posts, you can create your own post on this RUCKUS Lennar Community forum with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
Kind regards,
Sofia Gätjens
10-29-2023 05:31 AM
Thanks everyone.
