10-16-2025 08:28 AM
The Ruckus ICX 7150-C12P has no power.
Here is a link to the video demonstrating that the switch has no power.
https://www.youtube.com/shorts/z21o_uFgZ3w
Can you help?
Thanks.
Jun
10-16-2025 08:51 AM - edited 10-16-2025 08:52 AM
Hi Jun,
Thank you for posting your query!
I understand that your Ruckus ICX 7150-C12P is not powering on.
Could you please confirm the following steps?
Have you tried swapping the power cable?
Have you tested the switch with a different power source or wall outlet?
If the issue persists after performing these checks, please log a support case using the link below so that we can assist you further and initiate an RMA process if required:
Are you a Lennar Homes customer ?
I hope this information helps.
Please feel free to reach out if you have any further questions or concerns.
Note: Kindly mark this post as “Accepted Solution” if it addresses your query.
Mayank
10-16-2025 09:00 AM
Thanks for the reply.
Yes, I am a Lennar home owner
Yes, I tried other power cables and other power outlets.
I just submitted a support ticket. Case ID: 02110649
Thanks.
10-16-2025 11:38 AM
I am being told by Ruckus support that this needs to be handled here. Who can I work with to get the RMA started?
10-16-2025 12:02 PM
Hi @junjang
Based on the information and video provided, it appears that your RUCKUS Switch is dead.
Please use the private chat option to respond to the queries requested there. For your reference, I have included a screenshot below.
