10-14-2023 01:38 PM
There are no status lights on the unit. I unplugged the power cable and plugged back in. The amber lights flash for a quick second and then no lights at all. I can’t console into the device. I tried changing out the power cable from a working computer, and I've tested the power outlet. I tried to reset the device by unplugging the power cable, pressing the reset button with a paper clip and plugging back in. The amber lights flash quickly and then no lights at all. Please advise.
10-16-2023 11:05 AM
Hi @darren_dickerso
Thank you for the response and for sharing the requested information.
This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again and we appreciate your patience.
Kind regards,
Sofia Gätjens
