Ruckus AP Power line blinking and other lights are off
Deepika
We have ruckus AP on every level in our townhome and the power light is blinking. None of the other lights including 5G and 2.4G are on. Can someone please help with this issue
21 REPLIES 21
Hi @Deepika
Greetings of the day,
Please share the image of the switch and the access points showing the LED status and the cable connections.
Also please let us know how many access points are connected to the switch.
Deepika
Hello Jayavidhya,
We have four access points and please find the images below -
Lower levelLower levelGarage SwitchGarage SwitchGarage SwitchGarage SwitchSecond levelSecond levelFirstFirst
Hi @Deepika
Based on the images you have shared it seems that the ethernet cable coming from the router/modem is connected to the wrong ports of the switch. It has to be plugged into one of the 12 ports of the switch as mentioned below.
Here I will leave a short guide how to connect the devices properly :
Hi @Deepika
Please connect the ethernet cable to one of the 12 ports of the switch and check the LED status of the access points.
Once you are done with the above process please let us know the LED status of the access points.
