12-07-2024 05:02 PM
Hi Imran,
I followed the steps to reset entire unleashed network using the SSH option as detailed in method#3 given in this link:
and it worked. After doing factor reset of the master AP, now I am able to configure my master AP to connect my wireless network and the member AP also join the master AP as mentioned in above link.
The only issue i now have is i am unable to login into the unleashed mobile app on my phone using the same admin user name and password that i had set up on unleashed.ruckuswireless.com login page.
Any pointers for logging into the unleashed mobile app will be helpful.
Thanks,
Pravin.
12-09-2024 12:03 PM
Hi @pravinsv
I apologize for any inconvenience caused.
I recommend performing the upgrade during your non-working hours, as this will reboot the Access Points and may require you to create a new Wi-Fi network/SSID.
Please don't hesitate to reach out if you have any questions or need further clarification.
12-11-2024 04:24 AM
Hi @pravinsv
Thank you.
12-13-2024 04:03 AM
Hi @pravinsv
Thank you.
12-13-2024 12:37 PM
Hello Imran,
Will try with the firmware upgrade today evening after my working hours and will let you know how it goes, i couldn't try earlier this week as was a little tied up at work.
Thanks,
Pravin.
12-13-2024 12:54 PM
Hi @pravinsv
Sure, please keep us informed, and do not hesitate to reach out if you require any assistance regarding this matter.
