04-30-2024 05:36 PM
We own a Lennar home with a Ruckus box installed. We also have AT&T Fiber Internet. For the last 4 years we've refrained from using the Ruckus internet and opted to using the AT&T Router specifically due to connection issues. We run ethernet into a computer and have no problem connecting to internet on the Ruckus. However, when we attempt to connect to online game servers, and call servers, such as discord, we fail almost every time to connect. I just now got into the Unleashed Dashboard which shoes both AP's connected in the house, however it only shows we have wireless connections status and none wired connection when the ethernet that runs into the pc is directly connect to the ruckus box. We've gotten this far and need help!
05-01-2024 04:26 AM - edited 05-05-2024 10:55 PM
Check the configuration settings in the Unleashed Dashboard to ensure that wired connections are properly recognized. When it's done, give anwhatsapk a try.
05-01-2024 05:31 AM
Hi @ThomasW
As per the case description, I understand that you have some issues with the ethernet connectivity via the RUCKUS setup.
Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports.
Please let me the answer to the above query and let me know if you have any queries in this regard.
09-18-2024 05:11 AM
Hello @kashmalabaloch0
Thank you for your valuable suggestion. We sincerely appreciate the time and assistance you've provided.
Please don't hesitate to contact us with any further queries or concerns regarding RUCKUS Lennar Home setups.
Once again, thank you for your time and support.
01-01-2025 10:31 AM
test
