R510 AP red pwr light issue
Jflexx
I've got an R510 AP that I believe is stuck in boot loop. I have 2 AP's and both were working, and then I noticed that I've tried a few hard factory resets on it physically. I've unplugged and plugged it back up. I've changed ports on the switch. I've even switched ethernet cables to make sure the wire itself wasn't bad. I have a second AP that has no issues when resetting, but this one continues to have the red PWR indicator despite my different types of attempts to reset.
9 REPLIES 9
Hello @Jflexx
Thank you for your response and the information provided on the private chat.
We kindly request that you connect your RUCKUS R510 Access Points (APs) one by one to a functional power outlet and share both pictures and a single video showcasing the light status, the 12 VDC external power adapter cord connected to the APs, and its connection to a working power outlet. Please refer to the example pictures provided below for guidance. (Usually, you will find the 12 VDC adapter connected to your ISP’s (Internet Service Provider’s) Router/Modem-Router combo device.)
For the video upload, we have created a designated link for your convenience. You can access it via the following link: (Refer to the EXAMPLE VIDEOS from this drive link)
If you have any questions or need further clarification, please don't hesitate to reach out.
Got it. Please see attached for photos of the AP. I've uploaded the requested video of the ap as well to the shared drive link provided.
Hi @Jflexx
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, and checking all the connectivity and connections, the failure persists. And this is the only ONE access point that isn’t working with RED PWR LED on it even after checking with an external power adapter it behaves the same. This ONE Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Imran_ruckus
Community Manager
Community Manager
Hi @Jflexx
Thank you.
Jflexx
I've tried this, and using different ports does not work.
