05-17-2023 03:04 PM
I had to power house down to fix the A/C unit and I can't seem to get my LAN ports to activate. The access points work ok, I have the blinking green lights but nothing connected to the ports seem to get internet. HELP!!
06-01-2023 08:10 AM
Hi @MrAntCali48
Yes, I can see from the pictures shared, earlier your Switch was booted up on the secondary partition which is on SPR (Routing Code) and now you have your Switch booted up on the Primary partition which is on SPS (Switching Code). It must be on the SPS code for Lennar Home users.
Earlier:
Now:
To avoid this issue in the future please execute the below commands on the CLI to bring your Switch Secondary partition also on the SPS code. In case your Switch boots up on the secondary partition in the future due to power outage/power spikes there won’t be any such issues.
show version
copy flash flash secondary
Example:
05-31-2023 10:32 PM - edited 05-31-2023 10:37 PM
Ok I happen to watch Matt Klouda on the Ruckus Networks Education https://www.youtube.com/live/opuE1wjC77M?feature=share
and finally got in my ICX Switch! Here are the screenshots after I followed the steps as far as updating the routing code
Is this the correct setup at this point? 😅
06-01-2023 08:10 AM
Hi @MrAntCali48
Earlier:
Now:
show version
Example:
