10-28-2025 05:16 PM
I recently changed my Ruckus device and switched my network provider from CenturyLink to Xfinity. Since then, I’ve been unable to connect to the Ruckus device using PuTTY.
The Switch IP address is showing as 10.0.0.114. When I use it in the Telnet Host name, it does not allow me to open PuTTY.
Could you please advise on how to resolve this issue?
11-05-2025 09:09 AM
Hello Pinky,
My Internet provider asked me to change the router. I will change and give you the update by next week. Thanks.
Rajesh
11-05-2025 10:30 AM
Hi @tmrajesh
Sure. Please keep us informed on the status of the issue. If it gets resolved or if you require further assistance, just let us know, we are here to help.
11-07-2025 04:31 AM
Hi @tmrajesh
Thank you.
11-07-2025 09:18 AM
Hello Imran,
Thanks for the follow-up. I am still waiting for the new router from the service provider. Once It's done, I will check and get back to you. Thanks again.
Regards
Rajesh
11-07-2025 09:20 AM
Hi @tmrajesh
