02-09-2024 12:10 PM
I have no power to my downstairs access point. Also, I can access my unleashed account via web but not on the mobile app. Upon logging in I notice that my home network name is incorrect. Could you please assist?
03-11-2024 10:45 AM
Hi @ynv_naw
Make sure the management approval is enabled, as described in the below link.
If it is already enabled, please reboot (Unplug and plug from the power outlet) your RUCKUS ICX-7150-C12P Switch once and check if Switch gets listed in the Unleashed system.
03-11-2024 11:30 AM
@Imran_ruckus:
The provided link does not work so I reboot the switch and it caused more issues. The downstairs access point went back down so I had to go back through the steps using the command link. Turns out there are two bad ports as the cable was not being powered on with the two ports I put the cable in. It is now on after moving to a 3rd location. What is the cause of this? Could you provide another link to add the switch to the unleashed ruckus dashboard?
03-11-2024 11:31 AM
03-11-2024 11:44 AM
Hi @ynv_naw
If the link is not working please refer to the below screenshot to enable the same.
03-11-2024 11:55 AM
@Imran_ruckus:
I have completed this step and the switch still does not show on the dashboard
