04-30-2024 05:04 AM
Recently had a power surge run through my house and now my Ruckus devices aren’t working at all tried connecting it to a different outlet. No lights same results, seems to be completely dead. Looking for assistance with this issue, TIA.
04-30-2024 07:01 AM
I’ve resubmitted the video, showing me plugging in the ruckus in a working outlet.
04-30-2024 07:46 AM
Hi @Jtxa
Could you please try hard resetting of the Switch. Please refer to the below VIDEO for the hard reset process.
NOTE: IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please check and let me know if that works.
04-30-2024 07:57 AM
Tried the hard reset process and had no success, Switch is still not responding or powering up.
04-30-2024 10:03 AM
Hi @Jtxa
Thank you for sharing the requested VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up when plugged in. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
