My signal keeps dropping in my home
Scipe11
My internet connection keeps dropping in my home. Things will not connect to my network then it will or it will go offline. Need help .
13 REPLIES 13
I can’t download putty it does not allow me to do that. I have a MacBook.
Hi @Scipe11
I would suggest using Windows Laptop/PC if you have one. Below is the guide link explaining the process to get access to the CLI.
If you have a MAC device, please try the below process. (Also mentioned in the above link and please refer to the below screenshot)
Example "open terminal":
Telnet:
nc 192.168.1.182 23
SSH:
ssh admin@192.168.1.182
ssh super@192.168.1.182
Passwords can be Lennar or sp-admin or Ruckus1 or other default passwords shared below.
Please try to access CLI as explained above to get the command outputs, and share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
 This how far I get
Hi @Scipe11
Apologies, we are unable to see the picture you shared. Please share a Clear picture or a screenshot.
