My signal keeps dropping in my home
Scipe11
My internet connection keeps dropping in my home. Things will not connect to my network then it will or it will go offline. Need help .
13 REPLIES 13
Imran_ruckus
Hi @Scipe11
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, with unstable Internet.
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Monday it started with a spotty connection  going on and  off randomly throughout the day. I went to my unleashes app to check what was wrong couldn’t log in  but I fixed that problem with the IP address guide only thing is in the app it says my switch is not connected but the lights are on   Today it’s been off more than on and some apps work on my phone and some apps do not  IMG_2327.jpeg
 my internet connection stable and working.
I have 1 switch and 2 access points.
I NEED HELP IMMEDIATELY!!!!!!!!
Hi @Scipe11
Greetings of the day!!!
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike may be) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
Type a product name
