05-05-2026 10:43 AM
05-13-2026 03:16 PM
I’ve raised an RMA case and sent you a private message with the RMA details. You will receive further notifications from the RMA case. Please check and let me know if you have any questions.
Thank you once again for your patience.
If your issue has been fully addressed, please click the Kudos button and mark the responses as an Accepted Solutions.
05-06-2026 08:45 AM
05-06-2026 08:52 AM
05-11-2026 05:47 AM
Based on the troubleshooting performed, your ICX-7150-C12P Switch is not responding properly, and it is dead when checked with a working power outlet. A hard reset was also attempted; however, the issue still persists.
As a result, this Switch unit appears to be defective and needs to be replaced through the RMA (Return Merchandise Authorization) process.
To initiate the replacement, Please use the private chat option to respond so we can proceed further. For your reference, I have included a screenshot below.
05-05-2026 01:49 PM
When replying on the forum, you should be able to drag and drop the image or browse your device to attach it. Please refer to the screenshot and link to your post below for guidance.
05-06-2026 08:58 AM
Also, I tested the surge protector by plugging in a lamp with success so the surge is good. I also plugged the power cord (black) into another plug at the bottom of pic with green light with no success, but the lamp worked with the other plug.
So I think either the power cord is bad or the switch is dead. Unless there's a reboot method.
